Re: Mustard Algae in salt system pool
My neighbors have been putting bleach in the pool and following your instructions. I am still going to be out of town for another couple of weeks for work. My neighbors have agreed to work on the pool and put in any chemicals needed. I wanted to ask your advise on what chemicals and steps to take next to eliminate my problem. This is what I had previous done when I was in town a couple of weeks ago and found the pool green per instructions from the local pool store.
1. Added 2 - 6oz packs of Yellow shock & Clear.
2. Brushed pool surface.
3. Added 4 lbs. of granulated shock and left overnight.
4. Next AM I vacuumed the pool, backwashed for 2 - 3 minutes and rinsed.
5. Added 4 more lbs. of granulated shock and left overnight.
6. Repeated #4.
7. Repeated #5
By the next AM the pool looked very clear. I cleaned and backwashed. I then had to leave to go back out of town. In less than a week, the pool was green again. As I mentioned above, my neighbors have been adding bleach for the last two days. It looks much better. I wanted to order chemicals for them to continue trying to fix the problem but wanted your advise on what to get. Should I follow the same steps as above or something different. You have given me such good advise up to this point that I trust your judgement. Again, thank you for all of the help.
Karla
