Thread: Possible new in ground pool w/ Nature II
    Sep 2011
    Default Possible new in ground pool w/ Nature II
    We are thinking about putting in an in ground pool. The contractor really likes the NatureII system. Any opinions?
    Default Re: Possible new in ground pool
    Hello, and welcome to the forum.
    Yes, you'll get plenty of opinions on the NatureII system around here, but they won't be positive. Use the Google search function in my signature and see for yourself....
    Until your registration is complete, you'll probably need to log out to see the search results. But, Jan is right. NO NATURE 2!! It adds copper to your pool. Contrary to popular belief, it is not chlorine that causes fingernails and hair to turn green. It is copper!
    Furthermore your annual cost for the N2 cartridge will NOT be offset by your savings on chlorine. It doesn't replace chlorine, just reduces the amount you need, hopefully, by killing algae that uses up chlorine that you need to sanitize the dangerous stuff like bacteria.
    I bet the contractor sells the replacement carts for the N2. It is a big moneymaker at two carts a year! (I know, used to sell them!)
  1. nature 2 and bbb
    By go pens in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-01-2011, 10:34 AM
  2. pool care with the nature 2?
    By Baqout in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 11-07-2007, 11:29 AM
  3. Nature 2?
    By milynor in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-22-2006, 11:40 PM
  4. SWG & Nature 2
    By bbroglio in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-20-2006, 10:50 PM
  5. Nature 2?
    By milynor in forum Dealing with Algae & Slime
    Last Post: 04-10-2006, 08:54 PM
