Re: Intex Sand Filter - Just pooped in my pool!
I was going to comment like one other that maybe it had to do with some air getting in there and causing a small "explosion" in the filter. I have had my sand filter for 12 years and have never seen anything like that although I'm not so careful at times to bleed air out of the lines and such like I should. Does your vac just connect into the skimmer with the skimmer basket then the pump strainer in line with the filter? You mentioned a new pump, is it a higher horsepower/volume pump than you had before?
20,000 Gallon IG Vinyl (first season 2000)
Solar Heat
2 Speed Rebuilt pump
Sand filter
cooldude.com/pool-1.jpg
