Thread: I left the guy at Leslie's pool speechless with my water test results...
    BigDave's Avatar
    Default Re: I left the guy at Leslie's pool speechless with my water test results...
    Salt from the pool store? Is it cheaper than Solar Salt or better?
    Jul 2011
    Boca Raton, FL
    BigDave, I didn't even know what Solar Salt was until I Googled it (Morton's Solar Salt, yes?). I don't know whether it's cheaper or better. The salt I get from the local pool store comes in 40lbs bags and sells for $7 or $10, depending on whether you get pellets or fine granules. It doesn't have YPS (non-caking agent not recommended by Jandy).
    South Florida - 16,000g Diamond Brite pool, 700g spa & waterfall, Jandy 1400 AquaPure SWCG, Jandy variable-speed 1.5H pump, Jandy 60 DE filter, Jandy heat pump - using Taylor K-2006 kit
    Good Job! I'd be much happier to patronize pool stores if they weren't always trying to get you to buy what you don't need, or if you do, at 3 or 4x what it costs at the grocery store. Only Liquid chlorine, here in NJ, is a good deal at the pool stores.
