Results 1 to 10 of 10
Thread: Intex pool: can I fix the water or do I drain?
    Sep 2011
    Florida
    Default Re: Intex pool: can I fix the water or do I drain?
    THANK YOU for responding so quickly. It's such a relief to have this resource.
    I just tested my pool and chlorine is at 2.0 and ph is at 7.2. The donut feels a little slimy but the sides don't; I don't think my husband scrubbed the donut so I'll do that today. My test kit doesn't show chlorine levels above 5.0 but I'm guessing that doesn't matter; just use the formula you gave of 1cup bleach to add 1ppm chlorine. So if I'm at 2.0 then I should add 10 cups of 6% bleach? And does the intex pump do a sufficient job of circulating? I've been pouring the bleach where the water jets in from the hose. And since my ph is a tad low, how much borax (should I just look that up on the calculator?) and what's the best way to add it?
    I'd rather not have to calculate the CYA since I don't have a kit to test that and it's one more thing to do. So if I'm just using bleach what should I do, after today's shock, to maintain the pool? Also, I've got a net to collect leaves and the intex pump/filter. Between that and the bleach do I really need anything else to keep the water clean? (I've seen ads for vacuuming devices--more money!)
    Thanks so much for spelling this out for me!!
    Quote Originally Posted by swimg View Post
    I'm not sure you understand the choice here: on outdoor pool, you have two options:
    #1 - you can manage your CYA level, by testing, and maintaining enough but not too much AND a chlorine level appropriate for your CYA level
    OR
    #2 - you can have a pool that runs very badly, except when you are very lucky!
    There are three chemical values that are CRITICAL on ALL pools: chlorine, pH and stabilizer. On indoor pools, if you've never added CYA, you can assume CYA=0. But on outdoor pools you MUST have stabilizer (unless you want add chlorine 4x per day, on sunny days).
    So . . . it really comes down to what do you want more:
    => Avoid having to get another test kit, OR
    => Avoid having a pool a pool that's a pain to maintain.
    It's your choice.
    Sep 2011
    Florida
    Hi, you're right, I don't understand my choices. I bought the basic OTO kit because I read about it here, but it sounds like that's not enough? I don't have a problem with testing for the CYA if that's what I need to do. In which case, it sounds like that's my next step, after shocking my pool today--ordering a better test kit. And that will tell me how much dichlor powder to use or, if I'm using the floater with the trichlor tabs how long to use them. Do I understand this correctly?
    btw, I thought this thread vanished while I was typing my reply and I sent a query to the webmaster. Obviously I have found the thread (duh) so please disregard!
    Many thanks...
    The webmaster is me, so I just saw that. Glad you recovered it.
    OTO kits are usually available locally, and are better than strips. Taylor K2006 kits are usually NOT available locally, so when people have pool that's already running, we usually tell them to get an OTO kit (now) and a K2006 ASAP. It's not waste, since you'll be able to use the OTO kit for daily testing most of the time . . . but you'll need the K2006 to set things up, to check periodically, and to resolve problems.
    The K2006 includes a better pH test, plus CYA, plus a high range high accuracy chlorine test, plus calcium and alkalinity tests.
    But, NONE of the tests will tell you what to put in: they just tell you what's there. You have to LEARN what to put in, and what size doses to use, but we can help with that, once we have the test results.
    Sep 2011
    Florida
    okay, i'm beginning to comprehend...I will order the test kit tonight.
    Meanwhile, since I would imagine that my CYA level is really low, should I go ahead and shock my pool with dichlor powder? And if so, what's the best way to add it--broadcasting all around the pool? Pre-dissolving in water? I have suncoast fast-dissolving shock, 99% sodium dichloro-s-Triazinetrione Dihydrate.
    Thanks!
    I think I'd predissolve it and pour it slowly in front of the return jet.
    Your CYA may or may not be really low. If you've been using a lot of pucks, the CYA is gradually building up. Once you get your K-2006, test the CYA level and report it here.
    Sep 2011
    Florida
    I added the dichlor last night and the water looks nice and clear. The chlorine tested at 3.0 and the pH is a little low at 7.2. So do I raise it with Borax? And if so, what's the procedure?
    Many thanks....
  1. Greenish Water in Intex pool
    By lilchikypoo9225 in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-30-2013, 03:09 PM
  2. 18ft Intex pool help with well water
    By borntworide in forum Intex-type Pool Setup & Operations
    Last Post: 05-30-2013, 02:57 PM
  3. 12' Diameter INTEX Pool with very cloudy water
    By calalily1963 in forum Pool Chemistry for Intex-type Pools
    Last Post: 07-19-2012, 07:11 PM
  4. iron in water (Intex pool)
    By anikahmae in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 08-10-2011, 03:31 PM
  5. got new 24x5 round intex pool need help with water. Sandy water..help
    By iwannaswim in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-08-2011, 09:42 PM
