Thread: Pool heater options on our crazy home made pools
    Sep 2011
    Default Pool heater options on our crazy home made pools
    Despite 90 degree temperatures outside, out pool just isn't warm enough to enjoy. Its in a shady area and is darn cold.
    It is basically two "hot tubs", homemade out of concrete block and PVC pipe. When we bought the house, we decided they were worth trying to get running. With the help of a great friend and pool guy, they are up and running with a few issues to still work on.
    So we really don't want to invest much into these pools that may not last.
    Heaters: what's cheap? Redneck pool heater is amazing. What about a regular water heater?? Backflow preventer on one end and a pump on the other.
    Thoughts?
    Default Re: Pool heater options on our crazy home made pools
    As a former plumber -- held a master's license for 30 years -- I can assure you that you do NOT want to hook up an electric water heater.
    The ONLY cheap heat for pool is solar. The black plastic panels can add 5 - 10 degrees to your pool.
    SW Missouri
    Solar would be the cheapest after setup of course, and quite noticable for increasing your pool temp.. I noticed more benefit from my solar heating though in the spring versus the fall.. fall was when I wanted it more of course.. seems the overnight temps zap more heat out of the pool and you are lucky to recover it during the day so it's hard to keep up for long.. in the spring the nights keep getting warmer and you lose less so the solar really helps with an early opening.
    I have always wanted to come up with some kind of wood heat for the pool... I can get plenty of firewood for little more than my efforts.. it's my main source of home heat during the middle of winter..
    20,000 Gallon IG Vinyl (first season 2000)
    Solar Heat
    2 Speed Rebuilt pump
    Sand filter
    cooldude.com/pool-1.jpg
  1. Solar heater for above ground pools
    By Jlrymedic in forum Above-Ground Pool Construction & Repair
    Last Post: 09-10-2014, 09:33 PM
  2. Portable home made vacuum HELP! PICS INCLUDED
    By Antman2x2 in forum Pool Cleaning: Manual or Automatic
    Last Post: 08-12-2012, 07:23 PM
  3. Trying to move a swamp pool from one yard to another...I know we are crazy
    By Teena in forum Above-Ground Pool Construction & Repair
    Last Post: 08-09-2012, 11:19 PM
  4. Pentair MasterTemp Heater not for SW pools?
    By 26theone in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 02-01-2007, 06:46 PM
  5. IN-ground Heater options/round up
    By criis in forum Pool Equipment & Operations
    Last Post: 01-21-2007, 11:05 PM
