Rereading: I should probably use the chlorine tabs first, i they go off fast? Hrm. I'll read the instructions on them and on the chlorine feeder and try to figure out how to make that happen.
I'd put the chlorine tabs in -- A FLOATER, not directly -- just to use them up. They don't store well.
Otherwise, don't bother, till you get the test kit and test the water. The chlorine demand is going to be much greater than the amount of chlorine you have, so ultimately, it won't have any effect on the pool. But,you do NOT want to keep storing that tri-chlor.
Open those containers OUTSIDE, with you standing up wind, and holding your breath. If they've been sitting for over a year, whack the buckets HARD with a broom handle at arms length BEFORE you move them. Sometimes they can build up enough nitrogen trichloride -- which is a shock-sensitive but weak explosive, among other things -- when they are stored for a long time. If it's present, you want to 'blow the lid off', literally!, before you pick up the buckets.
Don't bother with the polyquat. It will be useful later, but it doesn't have the effect on surface tension cheap algaecide does, and that's what will kill your mosquito larvae.
Ditto on buying bleach, and stuff. A couple of gallons will only waste money.
Austin, TX climate info (from Wikipedia) suggests you don't need to worry about having winterized pipes and valves till December, so focus on the cover and the larvae. But, if the pump is not running . . . don't start it. By the way, you might want to consider operating budget effects from the pump: 2KW per hour, x Austin's electical rates, is a non-trivial expense and is far more than your 'operating' budget.
So, other than getting a cheap tab floater so you can use the tabs, just follow directions above, and worry about winterized pipes later.
But, if the pump hasn't be run in a year or more . . . you may not need to worry about that, either. Equipment damage has probably already been done, and will cost hundreds if not thousands to repair. Bad for the pool, but good for your CYA (Cover Your . . .) needs.
PoolDoc / Ben
floater and test kit bought. There goes this month's budget! :P
I'll stick three tabs in the floater this evening, not that I'm sure it'll do a lot of good with zero pol circulation. I'll stir it with the pool net, but until the water level's up to the skimmer, and until I know how the pump works, that's about all I can do.
Test ("Leslie's Basic OTO Poolcare Test Kit") says: Chlorine < 0.5PPM (very weak yellow, paler than the palest on the scale), pH > 8.5 (very rich red, deeper than the deepest on the scale). Water taken from elbow-deep in water, by the skimmer, not that the water reaches that.
The goal with the floater is NOT to "do a lot of good" but to "dispose of the tabs safely"! Fill the floater up!
OK. Your pH is high enough to be of some concern. Go to Lowes, and buy a gallon of muriatic acid (saw it for $6.50 today). Find a CLEAN 5 gallon plastic bucket with a handle. Fill it with 2 gallons of WARM water. Add 1/8 - 1/4 gallon of acid. Do this OUTSIDE, with sun or safety glasses AND glove on, AND near a gently running water hose at hand. Watch out for fumes. Once you've added the acid, use the water hose to mix the warm water and acid together, by adding some water directionally, to create a current in the bucket.
Leave the hose running, so if you need to rinse off a spill (on you, or on anything else) you can do so quickly.
Carry the bucket to the pool, and add 1/2 gallon of mix to multiple locations. Wait 2 days. Retest pH; if above 7.8, dose with acid again. Repeat til the pH is below 7.8 OR you are out of acid. Make sure you wait 2 days between doses; without circulation it may take that long to distribute.
Using warm water and highly diluted acid should keep the acid mix from hitting the pool bottom where it could be a problem.
Otherwise, my original list still applies.
PoolDoc / Ben
Thanks once again, and apologies for my denseness.
I will add more tabs when I get in tomorrow, then, and get the muriatic acid and cheap algicide at the next paycheck. I'm surprised it's so strongly alkaline - I thought oak leaves were acidic. Shows how little I know.
Lessee, how far am I on that To-Do list you gave me?
+ [...] add ALL the chlorine chemicals to the pool [in a floater]. The primary reason for adding this stuff is to dispose of it.
- In progress.
+ Post a list of all chemicals you have INCLUDING CHEMICAL NAMES (not brand or product names!) here.
- Done.
+ Get a cheap ~$10 OTO/phenol red test kit, and post pH test results here.
- Done.
+ Buy a quart of cheap 50% algicide at Walmart (~$15) and dump it in. It won't kill the algae, but the lowered surface tension will probably kill the larvae, without causing future pool problems. If you had more than 10# of chems, add the chlorine first, wait 2 days, and then add the algicide.
- Still to do. Waiting on paycheck. This one's actually to kill the larvae?
+ Get muriatic acid, mix and add per your directions.
- Still to do. Waiting on paycheck. This one's to prevent the acid etching the walls?
+ Go ahead and cover the pool.
- Still to do. Cover has gone missing. Likely in the garage somewhere, which will be an adventure in itself.
+ Post your location and we'll look up winter weather norms, before telling you how to winterize.
- Done.
+ Forget about cleaning up the water: with your budget, it's not an option, even if you use plain bleach.
- Done. *sigh* The hardest one you've given me, but I agree it needed doing
Questions:
1) What does a $15 plastic floater do more than, say, a loose-woven cloth baggie tied around a tab and a brick of wood? Assuming the brick's large enough to prevent the tab touching the sides of the pool, that is?
2) I won't add the other stuff until the chlorine's used up, unless you recommend otherwise: but is it OK to put the muriatic acid and the cheapo algicide in on the same day?
You don't have to wait for your next paycheck to lower the pH, You have Muriatic Acid and Dry Acid (sodium bisulfate) in your chemical inventory.
Another thought: Can you organize your colleagues to pitch in and try to get the pool back? If 10 more people can put up $15/mo like you are, you may be able to clean it up in the spring.
No need for apologies; no denseness is involved.
Tannic acid -- in oak leaves -- is acidic. But oak leaves are more than tannic acid, & have no idea what their overall effect is. Dunno why your pool is basic; only that it is.I thought oak leaves were acidic.
Yes+ Buy a quart of cheap 50% algicide at Walmart (~$15) and dump it in. It won't kill the algae, but the lowered surface tension will probably kill the larvae, without causing future pool problems. If you had more than 10# of chems, add the chlorine first, wait 2 days, and then add the algicide.
To prevent high pH from causing problems, of various types. But acidity causes etching, not basicity (high pH). Sorry about not checking your inventory list.+ Get muriatic acid, mix and add per your directions.
You should absolutely do as Big Dave suggested, and use up all acid sources BEFORE you buy more. BTW, trichlor tabs are also acid.
Regardless, follow earlier instructions about adding acid in highly diluted form with warm water, to prevent damage that could occur in an uncirculated pool otherwise.
Trichlor will destroy most forms of cloth, and some forms of plastic.Questions:
Yes, just not in the same spot.2) I won't add the other stuff until the chlorine's used up, unless you recommend otherwise: but is it OK to put the muriatic acid and the cheapo algicide in on the same day?
PoolDoc / Ben
From above list of chems in the shed:
"- TransChem "Muriatic Acid" 20deg Baume Hydrochloric Acid 31.45% - 2 x 1 gal" - unless you reckon it'll be horribly degraded by now, I'll try using those instead?
Muriatic acid doesn't degrade with time . . . but bottles do. Be careful to set things up, so that if the bottle shatters, you are protected (glasses, gloves, running hose!)
If it's still in a box, move the box OUTSIDE before opening it. If you have a large enough plastic bucket, put one gallon in the bucket -- gently! -- and then poke it with a not-sharp stick, to see if the bottle is brittle. If the bottle is OK, proceed.
Be SURE to store the bottles so sunlight does NOT reach them.
PoolDoc / Ben
