Thread: smoothing down the pool liner
    Oct 2011
    Default smoothing down the pool liner
    Hi, I've had an above ground pool for about 10years and have always enjoyed it. This year the floor has become a little rumbly from footprints. Is there a way to roll out these lumps without dumping any water ?? Thanks.
    Default Re: smoothing down the pool liner
    Welcome to the Forum!
    I think you are unlikely to be able to correct the floor without removing the liner and re-troweling the base.
    How's your liner holding up? At 10 years, you may be close to needing to replace it. If you can deal with the floor until the liner needs to be replaced, that'd be optimal.
    Oct 2011
    Liner has shown no sign of problems and I can not even think about that cost so I 'm looking at options to smooth off the floor so it doesn't feel so lumpy. I didn't understand the post about using a vinyl roller. Could someone explain that to me.?
