Thread: 2 Speed Century Pump Motor is now only 1 speed
    Default Re: 2 Speed Century Pump Motor is now only 1 speed
    Here's the AO Smith master service manual:
    http://www.aosmithmotors.com/WorkAre...=id&ItemID=588
    Unfortunately, more that that I don't really know. Specs here suggest there is a switch for low speed, but not high . . . though I don't know how that works.
    Ben
    We'll have to wait for Poconos. I do believe the unit has a low speed circuit, unless the switch is just bad.
    Honesdale PA
    I'm not familiar with these 2-speed motors at all. But, that 'covered bump' on top that you refer to is just the starting capacitor. Looking at the external wiring on the B979 drawing from here
    http://www.aosmithmotors.com/calcula...ult.aspx?id=57
    it looks like you connect to either the high or low speed windings via an external single pole double throw switch. Could be that switch is bad in the high speed position OR something else is open in the high speed circuit. Does it make any sound at all when in the high speed mode?
