Thread: smoothing down the pool liner
    Oct 2011
    Default smoothing down the pool liner
    Hi, I've had an above ground pool for about 10years and have always enjoyed it. This year the floor has become a little rumbly from footprints. Is there a way to roll out these lumps without dumping any water ?? Thanks.
    Default Re: smoothing down the pool liner
    Welcome to the Forum!
    I think you are unlikely to be able to correct the floor without removing the liner and re-troweling the base.
    How's your liner holding up? At 10 years, you may be close to needing to replace it. If you can deal with the floor until the liner needs to be replaced, that'd be optimal.
    Oct 2011
    Liner has shown no sign of problems and I can not even think about that cost so I 'm looking at options to smooth off the floor so it doesn't feel so lumpy. I didn't understand the post about using a vinyl roller. Could someone explain that to me.?
  1. In ground pool has pool drain cover plate trying to poke through the liner
    By ocgamer in forum Pool Equipment & Operations
    Last Post: 07-01-2011, 06:38 PM
  2. J-channel holding liner in corner broke off, liner is sagging
    By TRHOD12 in forum In-Ground Pool Construction and Repair
    Last Post: 05-09-2011, 04:41 PM
  3. Wrinkled Liner and Water Behind Liner
    By rbposey in forum In-Ground Pool Construction and Repair
    Last Post: 09-26-2009, 05:40 PM
  4. new pool liner
    By Pollysunshine in forum Above-Ground Pool Construction & Repair
    Last Post: 06-05-2007, 02:15 PM
  5. Pool Liner
    By crosso in forum In-Ground Pool Construction and Repair
    Last Post: 04-12-2006, 01:11 PM
