Results 11 to 12 of 12
Thread: help, do I need to drain my pool??
    Default Re: help, do I need to drain my pool??
    We used to say that if your water was under 50, then you didn't really have to worry about algae, Until my co-moderator Al (Poconos) found some algae growing under ice in his pool in northeast PA! Where do you live and what are your winters like?
    I would say you still need to keep the Cl levels at least at the minimum on the chart for your CYA level, but you'll find that with colder water it doesn't take adding chlorine nearly as often as it does with warm water to keep the levels up. If you shock the pool again now, you'll fnd that it stays a lot longer than it does in the summer
  1. I want suction from skimmers, main drain, AND spa drain - bad idea?
    By joelq in forum Pool Equipment & Operations
    Last Post: 05-03-2007, 08:17 PM
  2. need to drain the pool
    By tagprod in forum Pool Equipment & Operations
    Last Post: 09-09-2006, 10:29 PM
  3. Pool Drain or No Pool Drain (Skimmers vs. Jets)
    By michelle73 in forum In-Ground Pool Construction and Repair
    Last Post: 08-15-2006, 02:22 PM
  4. HOW do you partially drain a pool?
    By west1745 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-15-2006, 07:14 PM
  5. How to drain pool quickly?
    By jnorris in forum Pool Equipment & Operations
    Last Post: 06-14-2006, 06:22 PM
