Testing
To avoid damage to pools and spas from unbalanced water, test calcium hardness at least monthly. Calcium hardness is best monitored with a drop-count titration, as test strips can only measure total hardness. In addition, whereas test strips for total hardness have just four or five color blocks to cover a tremendously wide range—from 0 to 1,000 parts per million (ppm) with color blocks for 0, 100, 250, 500, 1,000, for instance—a drop test will allow you to approach the true concentration of calcium hardness in 10-ppm increments. This means if you're faced with wanting to balance water in a spa by increasing the calcium hardness from 60 ppm to 150 ppm, the strip can't help but the drop test can.
To perform a drop test, simply fill a test cell with sample water, add buffer and indicator reagents, and swirl to mix. The sample will turn red if calcium hardness is present. Next, add the calcium hardness reagent, swirling and counting each drop, until the color changes from red to blue. Finally, multiply the number of drops used by the equivalence factor in the test instructions to determine the calcium hardness level. The reading is expressed as parts per million of calcium carbonate.
The color progression in a hardness test is from red, to a mixture of red and blue, to blue. To be certain the color change is permanent, indicating you have reached the true endpoint, add one more drop of titrant. If the blue color remains unchanged, do not count this drop.
Beware the Fading Endpoint
Occasionally when testing calcium hardness you may get a purple endpoint instead of blue. This is called a "fading endpoint" and is due to interference from metal ions (most likely copper from algaecides, pipes, or source water). Retest, but prevent the interference by adding five or six drops of hardness reagent to the sample before adding the buffer and indicator. Then proceed as usual. Remember to count the drops of titrant added at the beginning when you calculate the total number of drops required to reach the endpoint.
