Thread: inground pool erosion under deck.
    Nov 2011
    Default inground pool erosion under deck.
    Hello,
    We bought a house that had been unoccupied for about three yrs and the in-ground pool was in disrepair. Vinyl liner was shot, and dirt had eroded from under the deck and created large caverns. Edge of decking nearest water seems to be supported by metal support structure.
    Is there a normal method of handling this problem, short of removing all the concrete deck, packing the soil and then re-pouring concrete?
    As the outer edge of the deck has settled, I've excavated a bit and place jacks to temporarily raise it.
    thanks!
    Default Re: inground pool erosion under deck.
    Hi and welcome to the forum! Sorry you haven't gotten a reply yet. Ben has had some issues he has had to deal with the past few days and thus he hasn't yet been able to move these new posts into the general part of the forum where you'll be able to get the advice of some of our builders. But, he'll hopefully be able to do so soon. So, sit tight. Just wanted to let you know that your post has been read and that you aren't being ignored!
    Hi Bow;
    If I'm getting a correct picture of your situation, I'm not at all sure that there's a good way to fix your problem, but Waterbear or Waste would know more. Give them a chance to take a look.
    As Lisa said, I've been preoccupied, first with my son's wedding and then with some unrelated but serious problems in my extended family.
    BigDave's Avatar
    Mazel tov! for the wedding - the other stuff, good luck.
  1. Brass deck jets versus Jandy deck jets
    By pumpkineater59 in forum Pool Equipment & Operations
    Last Post: 04-13-2012, 12:58 AM
  2. in deck or on deck slide and diving board
    By bszaronos in forum Pool Equipment & Operations
    Last Post: 03-16-2012, 12:52 AM
  3. moss on a carpet covered deck (factory pool deck)
    By JETTA in forum Above-Ground Pool Construction & Repair
    Last Post: 09-08-2006, 08:56 PM
  4. Need advice-- Wood deck, inground pool
    By hoogie in forum In-Ground Pool Construction and Repair
    Last Post: 07-20-2006, 11:43 PM
  5. What 50 years of Erosion looks like- just sharing our amazement
    By CallMeIshmael in forum In-Ground Pool Construction and Repair
    Last Post: 06-15-2006, 09:35 PM
