Thread: new member, new pool
    Nov 2011
    tucson, AZ
    Default new member, new pool
    Hi all,
    First post here, Just recently had a IG pool built, builder installed a ozone generator, which I'm learning was a waste of money, but it's also causes a issue with turning off the pumps at night. the tube from the ozone unit allows air to escape or get into the pump chamber and the water drains back into the pool. when the timer turns on the pump in the morning it doesn't pump because it lost it's "prime". I think this wouldn't be good for the pump. the builder has not gotten back to me so far. just thought i would get an experts advice from the forum.
    do they make a ozone generator that stops the pump from using it's prime when turned off?
    thanks,
    Dawgster
    Default Re: new member, new pool
    The particular problem you describe is common, but isn't necessarily the ozone mfg's fault. Your pool builder may well have installed it incorrectly: many builders do not know how to avoid pump bypass loops that can allow a pump to lose prime. In many cases, if the unit was installed with small tubing, you can simply bend the tubing till it crimps, and then use electrical tape to hold it crimped till your builder can fix it.
    Nov 2011
    tucson, AZ
    Thanks for your response. my PB claims that's it's just the way it works and to run the pump 24/7. I don't agree with running the pump 24 hours a day and if there's a power outage the pump would be damaged when the power is restored.
    does anyone know how to install properly? I rather get my money back on this equipment....
    Thanks,
    Dawgster
    bumping this post back up....
    Feb 2012
    Canada
    Dawgster,
    Are you still having an issue with your pump losing prime when it shuts off? There is no Ozone system (to my knowledge) that is meant to be running 24/7 on a residential pool. The recommended installation will depend on who the manufacturer of the Ozone Generator is. If you can post the info I can walk you through the correct installation procedures.
    Thanks,
    Brian
  1. New Member - Pool Newbie saying hello
    By rmergen in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-16-2013, 09:21 AM
  2. New Member with New pool
    By LarryW in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-29-2012, 01:28 PM
  3. New Member, yucky pool
    By Old Bat in forum Intex-type Pool Setup & Operations
    Last Post: 07-09-2012, 05:40 PM
  4. New Member - planning new pool
    By GregC in forum In-Ground Pool Construction and Repair
    Last Post: 04-17-2012, 07:23 PM
  5. New member and pool owner needs help.
    By mastamoon in forum Dealing with Algae & Slime
    Last Post: 09-16-2011, 05:44 PM
