It seems like you wired your pump wrong. The green wire is the ground - leave that one. Try to switch the other two. Here is a good wiring instruction for you (if admin doesn't mind):
http://www.inyopools.com/HowToPage/h...pool_pump.aspx
Dzeak7, your access has been upgraded.
PoolDoc / Ben
