Thread: Pentair Backwash Valve
    Jan 2012
    Default Pentair Backwash Valve
    I have a Pentair Backwash valve that is fairly new. It leaks at the top of the shaft at the handle when closed in the filter position. However, if I move the handle just a quarter of an inch countercloskwise ( toward the backwash position) the leaking stops. Presume it is the top oring. How do you lubricate or replace it. Any suggestions
    Default Re: Pentair Backwash Valve
    Which valve do you have?
    This pool product site has them displayed nicely: http://www.poolplaza.com/C-V-BW-PF1.html .
    Here's a photo of a typical side mount multiport:
    You may be able to repair it by
    (1) removing the lid
    (2) compressing the spring so the handle is unloaded
    (3) remove pin #18
    (4) disassemble
    (5) replace O rings #23
    (6) reassemble and reinstall.
    Of course, if sand has gotten into the stem, and scratched the sealing surfaces, O-rings won't fix things.
    Jan 2012
    I just have a push/pull backwash valve. I noticed today that it also drips a little out of the drain line even though it is in the filter position
    If your valve is like this:
    then here's your item list:
    Item Part Number Description
    1 51013811 Valve stem complete w/ handle
    1 51014311 Valve stem complete w/ handle, brass
    2 51013011 Nut
    3 51013500 O-ring, nut
    4 51013111 Reducer bushing, 2 in. male x 1-1/2 in. slip
    5 51003100 O-ring, cap
    6 51012911 Cap
    7 51014011 Body, with bulkhead fittings 8.0"
    7a 270052 Body, with bulkhead fittings 7.5"
    8 51005000 O-ring, valve stem, 2 in., 2 req.
    9 39102900 O-ring, bulkhead (2) * 8.0" Model only
    10 51013500 O-ring, bulkhead (2) * 8.0" Model only
    11 274494 O-ring, bulkhead (2) 7.5" Model
    Keep in mind that it's still true that if the surface the O-ring seals against has been damage, simply replacing the O-ring may not help.
    If you have another valve, you may have to wade through the PentairPool valve manuals: http://www.pentairpool.com/pool-owne...ction.php?s=51
    Pentair bought both American and StaRite, and has their slide valves. I don't remember whether PacFab (what Pentair used to be) had a slide or not, but I didn't see one listed.
