IMPORTANT: do NOT run your SWCG now, unless you are SURE it's OK to run it in cold weather. Most can't.
- Run the pump to get good mixing (4 hours maybe?)
- Make SURE your pH stays in range: 7.2 - 7.6
- Remove any leaves and physical debris, and keep it out.
- THEN, if you want to, you can clean up with chlorine.
In deciding how much to run your pump, here are a couple of things to keep in mind:
+ it's not winterized, so you MUST run it during freezing weather.
+ before doing any testing, you need to mix the water adequately.
+ if adding chemicals, you also need to mix.
+ chemical action is much slower in cold weather; chlorine still 'works', but algaecides may not.
If you want to do it 'my' way, I'd recommend doing the stuff above, AND ordering a Taylor K2006 (not K2005!). You can use the Amazon link in my signature. Once you've got the gook raked / skimmed / vacuumed out, you can test and treat.
But . . . if your stabilizer was high when you closed and is gone, or a lot lower now, you may have an ammonia situation. Bacteria can 'eat' stabilizer and 'poop' either ammonia or nitrogen gas. If the bacteria in your pool pooped ammonia . . . it will take HUGE amounts of chlorine to clean up. On the PLUS side, if you clean up with our instructions (high pH, borax to raise, bleach to chlorinate), you will form monochloramine at high levels. You wouldn't want to swim in it, but it's VERY effective at getting algae even back in the cracks and crannies.
However, before we can recommend starting that, you need valid test results . . . and test strips do NOT count, whether they are yours or the dealers.
