Results 1 to 10 of 11
Thread: Pool is gross but not ready to open it yet...
    Jan 2012
    Raleigh, NC
    Default Re: Pool is gross but not ready to open it yet...
    So I really wasn't trained when I got my salt-water pool...so I really didn't "close" it ... so I have no idea if stabilizer was high or not.
    Here's what I'm hearing:
    - buy the K-2006 test kit (will do)
    - get junk out of pool (will do)
    - run pump 4 hours (daily? or just before testing?) but ALWAYS in freezing/near-freezing weather (controls already do that automatically)
    - check out SWCG ...to see if it runs in cold weather. See below
    Here's more info on my pool:
    AqualCal PoolPilot Digital Salt Chlorine Generator Model: DIG-220
    Looks like it takes care of turning off purifier when it gets too cold.
    I haven't winterized but we don't get sustained sub-freezing temperatures usually.
    I do plan on doing "your" system... I'll start buying cheap, plain chlorine bleach from Walmart soon.
    Final question... should I worry about cleaning up the pool now or does it not hurt much to wait another month or so?
    I know that I'll need to rinse of the filter cartridge frequently until I'm ready to clean in earnest.
    Thanks for your help.
    Another month shouldn't matter; "or so" might.
    Get the kit, and let's find out what you're dealing with. If you have no CYA and no ammonia (I can tell you how to test), then you can wait. If you have CYA, not so much; what hasn't gone wrong yet, could soon. If you have ammonia . . . better start now.
    Otherwise, your family may go buy a hunting license for your hide, when the pool is not open and looking nice on the expected date = first really warm day in spring, usually. Trying to clean up an ammonia mess in a hurry is no fun: just check out some of the posts we'll get in May from that.
    BTW, a lot of folks here tend to think BBB = bleach, but it's my method, so I feel free to disagree. Bleach is just ONE way to do pools; when I started PoolSolutions (which preceded the PoolForum) bleach was cheaper, relatively, than it is now. Bleach has benefits, but so do other materials. Dichlor, trichlor, cal hypo can all work well IF you understand what they do and how to use them.
    (Not lithium hypo, and those AWFUL some form of chlorine + GOOP shock blends they sell today). I currently don't use bleach on my remaining local commercial customer -- it's not practical for me, since I no longer need truckloads of it -- but use a blend of SWCG's, dichlor and trichlor.
    Bleach is STILL probably the cheapest chlorine material you can buy in small quantities, but it's not nearly as cheap as a 50# bucket of dichlor or 40# bucket of trichlor at Sams. Cal hypo is now hard to buy inexpensively, and is a tricky product to use well - but it works really, really well if you know how.
    So, find out what you've got, and while we're waiting, check and see what's available to you locally (Sams, Walmart -- no blends!!! --, Lowes, etc.)
    Jan 2012
    Raleigh, NC
    Ok, Ben...got the kit (Taylor K-2006) and took readings today... I'll try to give extra details...just in case I screwed something up.
    Rained hard for a bit today...but pump was running after that for about 2-3 hours. I think it was running for 4 hours before I grabbed water in a cup about 1.5 feet under the surface...away from the jets.
    [Granted, the pumps don't seem to be pushing as much water...but filter might need to be sprayed again]
    Chlorine Test: Aborted...because
    Did 25ml test...put 6 dippers of DPD Powder and STILL didn't turn pink. Thought I'd try the other tests first then
    pH test:
    44ml of water
    Color appears to show pH above 8.0 but not by much.
    3 drops of "acid demand" seems to put it around 7.8-8.0
    4 drops total of "acid demand" seems to put it around 7.0
    CYA test:
    did the 7ml pool water, 7ml of cyanuric
    then dropped in to small comparator tube. Filled to top and could still see black dot clearly. My guess is that CYA is near 0
    Alkalinity Test:
    Did 25ml test
    6 drops changed color but not really to pink or red.
    7th drop definitely changed it to red
    so, 60-70 ppm total alkalinity
    So, I didn't run chlorine test again since without CYA I'm guessing that chlorine is probably non-existent in the water. But I'll try again if you tell me too.
    As a reminder...this is a salt-water pool. I'm trying to keep the junk out of the pool but can't see the bottom...
    I still need to check Home Depot/Lowes/BJ's for dichlo or trichlo
    Sounds like I could use one of those first to get CYA up...that's if I follow the different info I read on this site.
    Hi Mike and welcome to the Pool Forum. Since it appears that you have no chlorine and no CYA, dichlor might be a good option for you for awhile until your CYA level is where you want it. Then, you'll need to switch to an unstabilized form of chlorine like bleach or liquid pool store chlorine if it is cheap. (Even though trichlor is stabilized, it isn't a good choice for you right now because you can't shock with trichlor.)
    Unless I missed it, I don't think you told us if it is a vinyl liner pool or gunite, or plaster or ????
    Good decision to buy the K-2006. It will make things a lot easier for you!
    OK.
    On the DPD chlorine test . . . if you don't get pink with 1 dropper full, you won't get pink at all: you have no free chlorine. The ONLY time you might need 2 droppers full would be if you had extremely high chlorine (>30 ppm) and it initially turned pink, but then bleached out.
    HOWEVER, if you have zero with the powder alone, it's still possible you'll have a reading once you add KI (DPD reagent #3 -- potassium iodide) since adding the iodide will expose any chloramines present (or any non-chlorine shock, or some other stuff -- unlike the DPD #1, it's not a super-specific test.)
    Otherwise, it sounds like you're gotten reasonable results. Go ahead and buy a gallon of muriatic acid, to lower the pH, and if you can get a 50# bucket of dichlor at Sams, they usually have a super deal on it, around $2/lb, which is less than wholesale. But, I don't think they have it in stock in this area, yet.
    Alternatively, you can buy bleach which, at $2/gallon for 6% is about the same price comparing actual chlorine content. Once the dichlor comes in, you can switch to that. But go ahead and lower the pH a little now. Use only a pint of muriatic at a time. Do NOT measure it -- eyeballs are good enough. But DO read this page:
    http://www.poolforum.com/pf2/showthr...Your-Pool-s-pH
    so you do it safely. Muriatic acid is cheaper and better for your pool, but you do need learn to handle it safely.
    Jan 2012
    Raleigh, NC
    Thanks for the great info.
    Vinyl pool, inground pool. Roughly 25,000 gallons.
    Jan 2012
    Raleigh, NC
    So here's an update on my pool.... cleaned out the debris in pool and replaced filters...that helped a lot.
    Ran tests this morning and here's what I got:
    SWG, 25K gallons
    Chlorine:
    FC: 5ppm
    CC: .5 ppm
    pH: around 7.0-7.1
    CYA: 35ppm
    TA: 40ppm
    Guess I need to get CYA up higher for CWG pool.
    Can't really find buckets of dichlor here... I can find tri-chlor and calcium hypo
    I can find dichlor at $3/lbs in 5lb box
    So, any advice?
