OK, as stated previously, I live in south Georgia. I have a 25000 gallon outdoor liner pool. I use well water. The water sample indicates the following: FC 0.2, CC 1.0, pH 7.9, ALK 125, CYA 65 and water temp 57 degrees F. Based on acid demand (2 drops) and table E from the Taylor test kit, it says I need to add 46 fl. oz of Muriatic acid (31.45% HCI).
Do you all agree with this?
My circulation system is working fine and I run it about 8 hours per day. I will be adding bleach to get me chlorine levels back up. I am starting to get some algae growth. We are not swimming yet.
Thanks for any help.
