Thread: New pool owner
    Feb 2012
    Philadelphia
    Default New pool owner
    Just bought a house with a pool. I don't think my cover pump is working since I found it submerged. I tried opening the cover but it was too heavy to get all the water out, so I just covered the pool back for now. Should I be concerned about water building up on the pool cover? What are some resources I should check in order to learn how to clean and maintain the pool?
    Default Re: New pool owner
    The best resource you can use to learn how to clean and maintain the pool is the one you're reading right now! Take some time and read through as much of the forum as you can, and then read some more at our sister site, Poolsolutions.com. That should give you plenty of information to get you on the right track, and you can still post any questions that you have here.
    Is your pool inground or above ground?
    Too much water on the cover can pull the cover into the pool, and dump all that swamp water in. Better get (or borrow) a small electric pump and remove the water.
    But, FIRST, I'd check that pump to make sure it's not working. It could be that the GFCI just tripped, and that it will run if you reset.
    Yep. Been there, done that, have the ugly pics! Just another reason I don't cover my pool in the winter anymore!
    Want to send me the ugly pics, Watermom? I'll post them under someone else's name!
  1. New Pool Owner
    By HMSpool in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-20-2012, 10:32 PM
  2. New Pool Owner!
    By Kainoa in forum Pool Equipment & Operations
    Last Post: 11-13-2011, 09:35 PM
  3. new home owner -- new pool owner -- clear as MUD
    By Andyman33 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-06-2011, 07:51 PM
  4. New Pool Owner
    By bobcat in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-25-2010, 03:03 PM
  5. new pool owner
    By bingusboy in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 04-12-2006, 03:39 PM
