Thread: New pool owner
    Default Re: New pool owner
    The best resource you can use to learn how to clean and maintain the pool is the one you're reading right now! Take some time and read through as much of the forum as you can, and then read some more at our sister site, Poolsolutions.com. That should give you plenty of information to get you on the right track, and you can still post any questions that you have here.
    Is your pool inground or above ground?
    Too much water on the cover can pull the cover into the pool, and dump all that swamp water in. Better get (or borrow) a small electric pump and remove the water.
    But, FIRST, I'd check that pump to make sure it's not working. It could be that the GFCI just tripped, and that it will run if you reset.
    Yep. Been there, done that, have the ugly pics! Just another reason I don't cover my pool in the winter anymore!
    Want to send me the ugly pics, Watermom? I'll post them under someone else's name!
