Results 1 to 10 of 11
Thread: Not sure whats wrong
    Sep 2010
    Question Not sure whats wrong
    Ok, first off this may have been answered already but I'm not sure so Ill ask anyway.
    I realize its a little early but due to my wife hosting Bunco night in a few weeks I decided to get the pool cleared up. Over the winter, like every winter since I have had the pool, the water turns green. I began by testing the water with a k-2006 (bought last year thanks to this forum) and the proper chemicals to raise the PH and Alkalinity to good levels (I added a little each day for 3 days to get both to proper levels). Also while adjusting PH and Alkalinity, I kept the Chlorine at 20ppm. After 3 days I stopped loosing any chlorine overnight and the water was blue but cloudy. I should mention that this pool is 33' AG round pool and, with out getting in it, it is hard to get all the leaves out of the center. What I would do is get as much as I could then let the pool circulate and pull more leaves to the center then the next day pull more leaves out and so on until I got them all out. After the pool began to hold Chlorine I decided to brush the bottom ( I don't know why I decided to brush instead of vacuum but i did). The next day after brushing the water turned BROWN and is staining everything. At first it was clear with a brown tint. You could see stuff suspended all in the water so I thought that it would clear it self up in a few days. I have basically not done anything but maintain the chlorine lever for 3 days now and the Brown tinted water has turned into DARK BROWN water. Even when I draw a sample for testing, that water has a tint to it. I plan on vacuuming to waste today to see if it makes any difference. I have not added anything but shock, baking soda and soda ash.
    These are my reading as of this morning
    FC - 21
    CC - 0 <----not sure if this is good or not
    PH - 7.2
    Alk - 90
    Cal - 100 <---Vinyl lined pool so im not so worried about this
    CYA - 80
    Any suggestions?
    Brian
    33' AG 52" Side walls
    1.5 hp sand filter
    Had pool for 3 summers now !
    Default Re: Not sure whats wrong
    Hi, Brian, and welcome back to the Pool Forum. First of all, a CC of 0 is perfect. It is what you want it to be.
    Are there still a lot of leaves in the pool? You might try turning your pump off for a few days and see if everything will settle to the floor of the pool and then you can try vacuuming it up very slowly so as not to stir it up again.
    Once you can get the leaves out, then you'll want to run your pump 24/7 and let the filter do its job. You might try adding a little DE to your sand filter to help it filter out the small bits of stuff. You can read more about that here:
    Adding DE to a Sand Filter
    What kind of shock are you using? If it is dichlor, you might want to switch to liquid pool store chlorine or just plain unscented bleach. Dichlor is stabilized which means it adds CYA and your CYA is already high enough.
    Have you been adding WELL water? Do you have iron in your tap water? When you backwash your filter, what does the backwash look like.
    Some of what you are describing sounds like oxidized iron . . . and FC=21ppm would definitely oxidize iron, even with CYA=80ppm
    Sep 2010
    Ok I did another good sweep of the pool and I believe all the leaves are out now. I did go ahead and turn off the pump and will give it a day of so to see what if anything settles to the bottom then I will vacuu to waste.
    I have not added any water since last summer. As for backwashing I am doing it everyday and it's always very brown discharge water.
    #fingers crossed
    Brian
    1.5 hp sand filter
    Sep 2010
    OK I left the pump off for 48 hours and nothing changed. If anything the water might have gotten a little darker. I spoke with a lady that cleans pools (not an employee of any type of pool store) and she also mentioned that it sounded like metal. She thought that maybe me adding water here and there through out the summer last year that maybe sometime I had a little iron in my water. Just a note, I am on a community water system that gets its water from a near by lake BUT there has not been a licensed operator in the last 3 years so we have been under a "Boil Order". This might explain getting a little iron or something in my water. Anyway, after a little research, I added a bottle of Natural Chemisty's: Metal Free. I chose this because it was phosphate free. After 16 hours now there is no change in my water. Everything is still VERY brown and if its white, its stained. I still get brown water when backwashing, and like normal backwashing it clears up after a minute or two. Any suggestions? Is there a way to check for metal?
    FC - 13
    CC - 0
    ph - 7.0
    Alk - 90
    CYA - 80
    Brian
    1.5 hp sand filter
    You can usually ask your water system office for test results on your water. Alternately, you could take a water sample into any local pool store that does water testing and ask that it be tested for metals. When you dip a glass into the pool and get a water sample, does it appear brown in the glass?
    Also, take the lid off of your toilet tank in the house--do you see brown or orange staining on the inside of the tank?
    Sep 2010
    Yes the sample water I get with a glass is brown tinted but the water in my tank is not and there is no brown staining there.
    Brian
    1.5 hp sand filter
    Do you have a filter of any kind on the water that comes into the house?
    It may just be the breakdown from the leaves if you had a lot of leaves in your pool. Run your pump/filter 24/7 and see if whatever it is will filter out. Check your pressure on your filter before you start and watch and see if it is rising.
    Sep 2010
    No filter. I thought about it being leaves but the staining is so bad it will not wipe off. I do see the pressure increasing from morning to evening when I back wash. Maybe I need to just be a little more patient.
    Brian
    1.5 hp sand filter
