Re: Has anyone succeeded at shocking a green pool without using the pump to circulate
Back on the original topic!
Shocked the pool today with 4 lb of Lowes shock. The faint green is now more blueish though cloudy.
I've got the pump running and filtering. I'm a novice at this so I hope someone can kindly help with a few basic questions:
1. Our temp here is about 60 and the water temp is likely more like 50. How long does shock usually last and when to I begin regular chlorinating.
2. This is a vacation house and I live 3 hrs away. Is it ok to let a pump run for a week without backwashing (since that's when I will return). I have a large sand filter and it usually runs at about 18psi. If that's too long I'll just have to turn it off until I return next weekend.
3. I'v never backwashed before. About how long do you run it in backwash, and how long rinse? Am I right that when you back wash you open the valve on the pvc waste pipe at the same time? It's a standard multi-port valve on the filter, and I can't recall if it has a separate setting for backwash and a separate setting for waste.
Many thanks. sorry I know so little, though I'll know a lot more after the first time!
