By lowering the valve, you can remove a 90, the union coupling and the short section of smaller pipe between the valve and the union. But like I said, it is not that critical so if you want to skip that part, no big deal. The combination of all three things has an impact but nothing that would cause a problem.
Just keep the 2" to the pump and use all 2" pipe to the filter where you can use a 2" to 1.5" threaded adapter if that is what the filter requires.
This is really only needed when you have automation that does not support a timed spillover feature control but I think most controllers do now. A purely manual setup would not require the Spa makeup feature. The valving has two purposes. In pool mode, the extra valve allows for either a spa spillover feature and/or to fill the spa back up if the level should drop. If you are planning to go with a full controller including the actuators, then you might want to decide on the controller first before settling on the valving.
Ben, that configuration drawing actually came from Jandy (now Zodiac) originally and since there are no copyright markings, I would assume that it is ok to post at least the link.
