Re: Cannot seem to raise Ph
I agree with Watermom that you probably are bleaching out the strip.. However, you might just have much lower pH than you think, or a very high TA, which would take more Borax to cause a rise in pH than if you had a lower TA.
Either way, the way to figure it out is to follow Watermom's advice and get yourself a good kit.
