Thread: Opening test numbers...what do I do now?
    Tulsa, OK, USA.
    Question Opening test numbers...what do I do now?
    Just opened the pool and used the PS233 test kit, here are the numbers:
    FC: 0.5
    CC: 3 ppm
    TC: 3.5
    pH: 7.5
    Alk: 170
    Cal: 220
    cya: 0
    Temp: 67
    22' round AG pool, 10,500 gallons
    Appreciate any help on what I need to add to get my numbers where they need to be. Have used bleach and borax in past years. I'm pool illiterate and need help. Thanks so much for any directions you can give me.
    Carolyn
    Saint Cloud, FL
    Default Re: Opening test numbers...what do I do now?
    Welcome to the forum.
    Your CC at 3 ppm needs to be addressed pretty quickly.
    You will need about 10 gallons of 6% regular unscented bleach. Circulate for 24 hours and check the Cl ppm.
    Download Mike W. Smith's Bleach Calculator. (Do a search for him in the member's list) . Then do another calculation to see how much more you need to get the Cl ppm back up to 5 ppm. The idea is to get the CC down to less than 0.5 ppm.
    The CYA needs to be added as well. The calculator again will help.
    Keep us posted with your numbers, and we can help you further.
    Pat
    West, Texas
    Very good point watermom, thats a very good possibility
    Boyd
    27' Round AG, 17,204 gallons, sand filter
    Proud Father of an Army Soldier
  1. Opening numbers are in...
    By PBLsQuad450 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-26-2012, 03:06 PM
  2. my numbers after opening
    By roady in forum DPD-FAS based testing
    Last Post: 05-25-2008, 09:43 AM
  3. Opening Numbers
    By BigStein in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-07-2008, 10:12 PM
  4. Opening Numbers
    By SUNNYDAYS in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-04-2007, 05:48 PM
  5. Opening numbers
    By Poolidiot in forum DPD-FAS based testing
    Last Post: 05-13-2006, 09:38 PM
