Results 1 to 10 of 48
Thread: Light green water
    Mar 2012
    Iowa
    Default Re: Light green water
    After much filtering and back washing my water is crystal clear; however, I have no chlorine levels. Should I add more of the calcium and metal remover before chlorinating? I have a lot of algaecide 60 in to prevent algae while I was awaiting my new test kit. I think all the back washing took my CYA way down. Anyway here are my readings.
    Water temp - 69
    PH - 7.3
    Alk. - 200
    CH - 400
    CYA - undetectable
    FC - 0
    CC - 0
    Saturation Index - 1.0
    Oh yeah, my acid demand test was 2.
    Intex 16'x32'x52" model #54985 with ~14,500 gallons, filled with iron contaminated well water.
    No! Don't add any more of the Metal product (20% HEDP)
    How did you get such high calcium levels? Is that much calcium present in your fill water?
    You have a sand filter, right? If so the best way to run your pool might be with calcium hypochlorite and high stabilizer. I've been working a chemical guide page, and was very surprised to discover this AM that cal hypo can be purchased fairly economically at Amazon . . . if you know what to order.
    The benefit, for you, is that doing it this way -- with a sand filter -- would allow you to continuously remove iron from your water. You'll end up with a manually dosed pool running with high calcium, moderate alkalinity, fairly high pH and high stabilizer. It won't be hard or expensive at all -- just a little different. If you get a K2006 (yeah, I'm still on that track!) you'll probably be able to work up to dosing just 1x per week, plus whenever you have to add water.
    You could also use dichlor, and wouldn't have to add stabilizer manually. It will be more work to control the metals, whenever you have to add water, if you go that way.
    MEANWHILE, add bleach in the evening, 1/2 gallon at a time to maintain your pool while you decide. But, the first time you add, add 1 whole gallon of 6% plain bleach, close to sunset. Test the water first thing in the morning, and again in the evening with OTO, not DPD. Let me know what you find.
    Mar 2012
    Iowa
    I did get and used a Taylor k-2006 test kit. That's what my last results came from. The calcium must be in our well water. Yes, I have a sand filter but thought Icouldn't use cal hypo because I have a vinyl liner? I have a SWCG but don't have it on yet. Should I just start that?
    Wow! That is truly bizarre, if the calcium is the well water. OK.
    1. Cal hypo is fine in vinyl IF you don't drop it on the liner. (That's not why I want it in the skimmer, but adding it via the skimmer serves the purpose.)
    2. You have the Intex SWCG w the copper? Can you disable the copper part? (Regardless: NO, don't start it yet. We need to get everything right, first.)
    3. Please test your fill water, directly from whatever source you fill your pool. Please run it for at least 2 MINUTES before you collect a sample, so we're testing what ends up in the pool when you fill for awhile. (Ideally, collect your sample after you've been using water in the house, so the well pump has been running. But STILL run it for 2 minutes.)
    [ Just had a thought: could you have rusting pipes putting the iron in the well water? It's just very, very unusual to have calcium and iron in the same well water. ]
    4. If you can find a really clean white bucket, fill it with this water, after you collect a sample and then cover it with a towel, to keep dirt and sun out, but not air. Check it after 24 hours, to see what if anything has settled. And THEN test it.
    (Don't run CYA test on any of these samples: it will use up your reagent, and you already know there's no CYA in that water. Unless you have a chlorine feed pump, you don't need to check chlorine in the well samples.)
    Mar 2012
    Iowa
    I have a doctor appointment in the city tomorrow. I will stop and get cal hypo and do the testing of hydrant water when I get back.
    about 1/3 lb in the skimmer at a time. You must be 100% sure no other chemicals are in the skimmer, or anywhere between the skimmer and the filter. The pump must be on, and remain on for at least 30 minutes after.
    Mar 2012
    Iowa
    Sorry I haven't replied sooner but am 45 and 7 months pregnant. Have not been feeling well. Anyway, my pool is a slight color away from being clear. I tested my hydrant water which is where we fill from. The PH is 7.2, alkalinity is 375, and calcium is 310. I just received a test bottle from our health department to test our iron, manganese, and copper. I will have those in a couple of weeks. However, I expect it to come back high in iron and possibly manganese too. I know the copper isn't high because I've tested that and besides our house is old enough they used cost pipes not copper back then. I have a question. I'm pretty sure I killed any green algae there may have been. However, every morning when I go out and look there is a dark green or brown sticky substance along all the seems. Would that be black or mustard algae? How do I get rid of it because heavy shock, brushing, and vacuuming does nothing, it just comes back.
  1. light green water due to metal in my well water
    By marios in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-17-2013, 08:48 PM
  2. store bleach , light green water
    By fhorta in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-13-2012, 02:19 PM
  3. New to Saltwater System, and have a light green tint of water
    By carriermom in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-19-2012, 08:47 PM
  4. My Deep Blue Water is Now a Light Green-Blue???
    By Spike in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 01-25-2012, 02:01 PM
