Yes, the K-2006,
10ml,
yes, you have the scenario correct
yes, it was green
It's hard for me to tell about the drop because I often test late at night and add bleach then. I'm asleep before an hour of circulation to see what the actual level is before I go to bed. I will try to take a more accurate reading tonight/tomorrow.
BTW - Can hubby get a sample in the early a.m. and leave it on the counter with the cap on? He's the morning person. I am not. Would the readings be accurate that way, or does it need to be fresh?
Another question - since my CYA is so low, could I use the chlorine from the pool store in this instance? It sure would cut down on my trips to Sam's, but, also, I was wondering if it would help - it is stablized, isn't it? It's so hard to keep the chlorine levels up w/so little stabilzer in the pool.
Thank you,
Jennifer
