Page 3 of 3 FirstFirst 1 2 3
Results 21 to 25 of 25
Thread: Is there an ideal cyanuric acid level?
  1. #21
    May 2011
    Southeast Massachusetts
    Default Re: Is there an ideal cyanuric acid level?
    Thanks guys...Great help as usual.
    By the way. I have a Wanda The Whale coming this week...largely in part to your recommendation W.M. I rather enjoyed doing the vacuum work by hand last summer when it was warm enough to be in the pool. It did take a lot of time though and I'm hoping Wanda works like a charm.
    15,000 Gallon AG -24' round -- Vinyl Liner -- 1 HP Hayward Power Flow LX -- Sand Filter -- PF=5.5
  2. #22
    I think you'll be pleased with Wanda. I actually have two different auto vacs. Wanda is good for walking around getting dirt and little stuff and my Polaris 65 is good at getting big stuff. I use the Polaris more in the spring when the trees are dropping lots of stuff into the pool and again in the fall when the leaves start dropping. The rest of the summer I use Wanda. Having said that, like you, I also enjoy vacuuming manually while in the pool. It does take awhile but in all reality, I can get the pool cleaner that way than using Wanda or Polaris. So, I still do it that way at times. But, Wanda is nice and I can be lazy and let her do the work! Let us know how you like it.
  3. #23
    May 2011
    Very pleased thus far with Wanda. As long as the pump doesn't lose prime she runs for hours unattended...
    Back on the CYA issue...
    I decided to buy a smaller bucket of trichlor pucks...but I did not have a chance to go to Sam's club. I bought a 15 pound bucket of Robelle Jumbo (Slow dissolving) tabs. Now I'm worried after reading Ben's posts about many manufacturers using fillers. I'd like to list the ingredients as listed and confirm this product is okay. If someone with the knowledge could chime in that would be very helpful.
    Ingredients listed as
    Trichloro-s-triazinetrione*.....99%
    Other Ingredients .................1%
    Available Chorine.................90%
    *trichloroisocyanuric Acid Dry
    Thanks in advance. I know how busy you are moderating. I appreciate your time and help.
  4. #24
    May 2011
    Okay...I think I answered my own question. I compared the Kem-Tek product to the Robelle product...same exact active ingredients so I think I'm okay with the Robelle product.
    Bought it at Benny's (SE MASS) which is a smallish family owned department store...
    No reply necessary unless I've missed something. Thanks in advance anyways cuz I know you probably took the time to read it.
  5. #25
    . what you got is fine. -ben
  1. Fiberglass pool with high cyanuric acid and copper level
    By donnalubbq in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-11-2013, 10:42 PM
  2. cyanuric acid level is zero
    By ksue44 in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-08-2012, 12:18 PM
  3. Ideal Salt Level Pool Pilot
    By smallpooldad in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-26-2008, 11:46 PM
  4. CYA Reducing Mix Period/CYA Ideal Level?
    By smallpooldad in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-12-2006, 01:14 AM
