Thanks for all of the replies.
I haven't done anything but skim and brush the pool. We just bought the house.
Here's a pic of the filter......just a little dirty, huh.
Inground pool with Hayward Super Pump
That's a DE filter -- dirty, but otherwise looking OK, and not overloaded with DE powder.
It's a PacFac / Pentair Pool FNS DE filter. Here's the Pentair brochure
http://www.pentairpool.com/pdfs/fnsplusDS.pdf
and instruction manual
http://www.pentairpool.com/pdfs/FNSPlusOM.pdf
which you will want to read. You'll also need to find out which model you have -- that will put a limit on what the maximum flow and pump size should be.
Be careful with the grids -- they are dacron sail cloth over a fragile plastic grid -- and the grids get more fragile over time. The grid assemblies are usually not cheap, though I haven't looked up costs on that unit.
And, when you re-assemble the filter, be CAREFUL to clean both the tank O-ring *and* the groove under the O-ring. Dirt there will often cause a slow leak, and can damage the ring (also usually not cheap). Also, be careful not to stretch the O-ring . . . or it will be too big to get back into the groove. (No fun to be had there!)
PoolDoc / Ben
Thanks for the the pdfs Ben. They are going to help a lot! I'm glad to hear that it's salvagable. I'll definitely take my time so I don't damage the grids, I still have over a month before the water temp will come down so there's no rush.
