Results 1 to 10 of 15
Thread: new pump needed
    Mar 2012
    Las Vegas
    Default Re: new pump needed
    They don't list what the other ingredients are in the cal hypo. I have a Leslie's basic pool care dpd test kit, is this the one I need for now?
    I am looking to change what I do to this pool because I believe I may be the one who ruined the finish on the gell coat of the pool by not properly maintaining it. I don't want that to happen again to the new surface, that is why I am looking for advice from someone who actually knows pools and works with them, not just someone who wants to sell me chemicals.
    I think I read on this forum somewhere that on a fresh fill you should add bleach at about 1/3 full then 2/3 full and then more when completely full, is this correct for my type of pool? I will be around most of the time it is being filled so shouldn't be a big deal if I have to sit on it and make sure I get it right out of the box.
    12x30, 14,500 gallon FG in-ground pool, intelliflo vs pump, Hayward 175 sq ft cartridge filter
    If you've got trichlor, I'd buy a cheap floater and a couple of boxes of borax at Walmart.
    1. Start filling but do not let the hose water strike the pool directly. Instead, put a *clean* plastic bucket in the pool, and let the hose go into the bucket. Put a trichlor tab in the bucket. Filling via a bucket this way reduces the chance of iron spotting, if there's some iron in the fill. Putting the trichlor tab in the bucket keeps a small amount of chlorine in the fill.
    2. Once you have a 1 foot or so of water, put the floater in with some tabs in it and pour a box borax in the bucket. (Borax and trichlor are one of the very few combinations of pool chemicals that can touch each other!)
    3. Start the pump as soon as possible, but again, avoid having jets of water aimed at the pool surface.
    4. Keep the pump on 24/7 till the pool is filled and adjusted.
    5. Order a K2006 -- the Leslie's kit is OK to start, but . . .
    6. Except for staining, I'm not aware of water chemistry ruining gel coat. When you say yours was 'ruined', what exactly do you mean?
    Mar 2012
    Las Vegas
    There was spots on the pool where there was no gel coat at all and we were looking at bare fiberglass. I was told this was caused by not keeping the proper ph levels. It is an old pool and there was so much chalk on the surface we thought we had a white pool but after sanding it all down realized we indeed had a light blue pool. I just don't want anything like that to happen again and I'm a little nervouse about the epoxy paint holding up for at least a few years. I followed all the directions per the manufacturer and love the results, just want it to last.
    Quote Originally Posted by bomberchamp View Post
    I don't blame you. That is a LOT of work!
