Results 1 to 8 of 8
Thread: ecopoolpump vs pentair
    mas985's Avatar
    Pleasanton, CA
    Default Re: ecopoolpump vs pentair
    The VS-3050 does not have the SVRS. This is the way I would show it:
    011012 IntelliFlo VF => IntelliFloŽ VF High Performance Pump
    011013 IntelliFlo VS-3050 => IntelliFloŽ Variable Speed Pumps - Old Version
    011017 IntelliFlo VS SVRS => IntelliFloŽ VS+SVRS Variable Speed Pumps
    011018 IntelliFlo Variable Speed Pump => IntelliFloŽ Variable Speed Pump - New Version
    P6E6VS4H-209L IntelliPro Variable Speed Pump => IntelliProŽ Variable Speed Pump - New Version
    P6E6Y4H-209L IntelliPro VS-3050 => IntelliProŽ Variable Speed Pump - Old Version
    P6E6XS4H-209L IntelliPro VS SVRS => IntelliProŽ VS+SVRS Variable Speed Pump
    The old VS-3050s are not shown on the Pentair web site anymore but you can still buy it in some locations although since the new VS costs the same, I don't think anyone should go that route.
    Mark
    Quote Originally Posted by mas985 View Post
    I'm not sure if I understand -- are you saying that there are two VS-3050's, and that one of them is no longer there?
    Because there is a VS-3050 on this page:
    http://www.pentairpool.com/pool-pro/...d-pumps-76.htm
    right now (30 Mar 2012)
    mas985's Avatar
    Pleasanton, CA
    Ok, I think I understand your confusion. Pentair is phasing out the VS-3050 (011013) and is being replaced by the new "IntelliFloŽ Variable Speed Pump" (011018). They have removed most of the VS-3050 information from their pump page listing and only is shown on the "Specs" tab of the VS+SVRS which I think is an oversite. But even thought VS-3050 shows up on that one page, the VS-3050 is a different pump than the VS+SVRS. They have different interfaces and different feature sets.
    So here are the current website links to each pump
    http://www.pentairpool.com/pool-pro/...ce-pump-77.htm
    011013 IntelliFlo VS-3050 => Is not shown on the pump page listing anymore (except for the VS+SVRS "Specs" tab)
    But you can find the manual here: http://www.pentairpool.com/pool-pro/...ction.php?s=42
    http://www.pentairpool.com/pool-pro/...d-pump-430.htm
    This brochure shows all four pumps:
    http://www.pentairpool.com/pdfs/greenpentairB.pdf
    This listing may help as well:
    http://www.poolplaza.com/C-Intelliflo-Pump.html
    Mark
    mas985's Avatar
    Pleasanton, CA
    On the forums, I have only heard of a couple of failed drives but not many given the number of owners of the Intelliflo. It seems to be fairly reliable but I too have my concerns about the high power drive electronics. VFDs have been around for a number of years for other applications and have shown good reliablity although most are indoors or in a NEMA outdoor cabinet so this application is a little bit different. I guess only time will tell.
    Mark
