If you are feeling experimental, you could try lime-softening, which involves pushing the pH up over 10 with soda ash, precipitating the calcium as calcium carbonate, cleaning the System-3 beasts to remove the calcium, and then using muriatic to strip the excess alkalinity. Now that A&H washing soda is available at Walmart, it shouldn't be too expensive.
The Kem-Tek chemical developer says they've been doing this with Intex pool owners, and is willing to help me walk folks through the process. But it's not for beginners, till we've got it down. You'd need to turn off your SWCG and heater (if any) before starting. But, you should be able to take your calcium down to an arbitrarily low value, and remove most any stray metals in the water at the same time.
