Thread: Above ground pool
    Apr 2012
    Kansas City, MO
    Default Above ground pool
    We are looking for a "starter" pool. Probably an above ground DIY pool. What would be a good brand to start with? Something around 24' by 52"? Thank you!
    Default Re: Above ground pool
    Intex pools work well, if you avoid their salt system AND never let the pool turn green (we can help with that). The filters are too small, and take forever to clear the pool if it gets slimed.
    You can look at their line here:
    http://www.intexcorp.com/index.php/h...und-pools.html
    24' is kinda big for a DIY starter pool. In the US north-east, those tend to be 'final' pools . . . and they are NOT DIY, unless you are pretty handy AND do careful prep work. Intex has a 16x32x52" pool, that you can install yourself, if you want to go that route.
  1. Using an in ground cleaner in an above ground pool
    By Johnnymac in forum Pool Cleaning: Manual or Automatic
    Last Post: 07-11-2012, 09:03 AM
  2. Whats the difference between in ground and above ground sand filters ?
    By sherriemoseley in forum Pool Equipment & Operations
    Last Post: 05-26-2012, 01:31 PM
  3. Filling our NEW AGP now, but need help with ground wire/ground field?
    By TheVanDams in forum Above-Ground Pool Construction & Repair
    Last Post: 06-23-2011, 11:38 PM
  4. Above ground pool ladder - ground had to be leveled 1' down in yard
    By lori0479 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-21-2011, 01:50 PM
  5. Investigating partial in-ground/on-ground pool
    By jcmjrt in forum Above-Ground Pool Construction & Repair
    Last Post: 07-23-2006, 06:31 PM
