Above Ground Hose questions
I currently have my filter 15 ft away from my pool. I used the basic hoses to connect the filter to the pool last year. I noticed from moving the hoses, i caused some leaks. I wanted to switch to a better hose. Will Tiger flex solve this problem? What would I need to buy in order to install it? Also is this an easy install? I got quoted about 400 bucks for a pool store to do it. i think this is very very high.
