Thread: Above Ground Hose questions
    Default Re: Above Ground Hose questions
    Sounds high to me . . . but I haven't seen the pool or the hose. There's some weird stuff out there, that's hard to match up, and I don't know what you have. If you want someone to take an intelligent look at it, send pictures of the pool, the connections, the pump and the filter, and the existing hoses to [email protected], and I'll post them.
    Of course, if you don't want to do pictures, there is an alternative: send exact info about your piping and fitting OD, ID, construction material and construction type.
    But, even I don't know the technical designations for all the different pipe and tubing sizes used by above ground pool makers . . . so I couldn't do it!
