Thanks for all the help my PH is 7.6 my Ta is 60 ppm how can I raise the TA without raising the PH? Thanks Jerry
Fiberglass in ground, outdoor 6500 gal; Hayward chlorine dispenser, cartridge filter, & 1 HP pump; 10 years old
You can raise the TA by using plain Arm & Hammer baking soda, but if you're going to use unstabilized chlorine from here out, the TA is just fine at 60 ppm.
Janet's right, of course.
But, why do you want to raise your TA? It's a fiberglass pool. With your CYA that high, you are going to have to run VERY high levels of chlorine to avoid algae. Using bleach won't lower your CYA; it will just keep it from going higher.
You'd be better off adding borates (and acid) to get additional pH stabilization in the water. LOW carbonate alkalinity -- the part of TA that baking soda raises -- inhibits algae. High borates ALSO inhibit algae. On your pool, 6 boxes of borax, plus 2 gallons of muriatic acid should get you there.
Read this thread: http://www.poolforum.com/pf2/showthread.php?13111 about using muriatic safely.
PoolDoc / Ben
When testing water with regents does temp ( 50 F ) affect readings Thanks Jerry
I don't think so, but it will slow reaction times, so you may want double or triple the time you wait before reading, especially on the chlorine and CYA tests.
PoolDoc / Ben
how much bleach is needed to shock pool 6500 gal fiberglass pool thanks Jerry
In your pool, each quart of 6% bleach will add about 2.3ppm of chlorine. Shock level needed is based on your CYA level. See more about this in the Best Guess Chlorine Chart in my signature below.
