There's no absolute answer; most of the time, if it's more than the minimum reading, shocking is a good idea. But, some pools tend to run a bit more CC, and if it's not causing a problem . . . then it's not a problem. The minimum reading is 0.2 with the 0.2 ppm drop test, and 0.5 with the 0.5 ppm drop test.
