Using bleach to maintain your chlorine level is what most of us do--it's easy, relatively cheap, and doesn't add anything to your pool that you don't want it to.
Keep your filter running--the chlorine killed the algae, but it's the filter that will remove the dead algae that's causing the cloudiness. Hang in there!!
