Thread: Vinyl liner - poor install, need advice
    Apr 2012
    Phoenix, AZ
    Default Re: Vinyl liner - poor install, need advice
    Thanks Ted - Ironically enough I am from Maine ( grew up in Winterport and Bangor area till I moved to AZ 7 years ago) too.
    Water is not too bad but it's not free and I don't like to waste if I don't have too. I was under the impression I should never full drain the pool because of complications and problems I might run into ( getting it back in the track, sagging, etc). Maybe it's not a big a deal. Water is still kind of cold here so borrowing a wet suit and doing some diving this weekend.
    Monitoring the leak this one seems worse then the 3 small holes found last summer. I lost about 4 inches in a 24 hour period and this is for 18 x 36 pool so it's pretty significant. I don't think it's in the piping or around pump filter because it seem to leak the same amount weather it is running or not.
    Of course yes,I have an auto-vac! Lol....no main drain, only suction side cleaner, runs about 3 hours in the winter and up to 8 in the hot summer months. I know that is not helping the cause and def prob helping those little rocks stick through, as long I can keep them patched and maybe per-patch other rocks sticking up maybe I will be ok. Just frustrating with a new liner and the company who put it in not willing to help.
    Is there a better way to try to find these me leaks? Homemade dye solutions? Last time I had to have my face right against the liner and still could barely see the hole. I used food coloring and that didn't even alert me that much.
    Thanks!
    in-ground liner rectangle
    One of the other mods, Poconos, has recommended beet juice for detecting leaks...
