Re: Upgraded Intex Easy Set pool pump and now have questions....advice please!
I used both the Intex brand and ones I purchased at Walmart and the shock damaged the plastic on top and bottom of the A/C cartridge. It would start to eat through it and the plastic became 'gummy'.
I do have a camera and will take photos in the morning when it's light out (it's 8pm here now). I looked at the link your provided and it is the same skimmer. I think I may need an adapter that leads from the host at the bottom of the skimmer basket to the strainer inlet on the inside wall of the pool. The one that I replaced had threads on the strainer and the adapter that is on the end of the hose coming from the skimmer basket attached to it. But the strainer with this new pump is much larger and the adapter does not fit. So I looked on eBay and did see a 4 1/2 inch strainer adapter which I think I need to attached the skimmer basket. There's no mention of it with the new pump so I guess I was supposed to figure that out myself. I'm still looking though for the correct information. Thanks for the info you've given me!
Karen
18' x 48" round Intex Easy Set with 2,500 gph pump & cartridge filter
