Results 1 to 10 of 13
Thread: Upgraded Intex Easy Set pool pump and now have questions....advice please!
    May 2012
    Oklahoma
    Default Re: Upgraded Intex Easy Set pool pump and now have questions....advice please!
    I know you probably don't want to hear this, but I am just about ready to dump the cartridge filter setup and go with the big sand filter pump setup from Intex. I think it is rated at 2650gph flow rating. It comes with a real strainer basket like real pool pumps.
    What I am getting at is I have the same pump/filter setup as you on my much smaller 10' metal frame pool and I use the bigger return/inlet parts that came with that pump on my little pool. And the valves certainly make it easier to change cartridges without loosing a bunch of water. You would have to cut your opening slightly bigger to fit those fittings in versus what came originally with your pool. I have no issues with anything NOT using a skimmer basket...inlet suction is NOT a problem unless you take the cover off then decide to be cute....it will suprise you with it's power and you can just stick a hose in it and use a cheap brush/vacuum that is sold at most places.
    The only thing I don't like is changing filters every week for me, BUT never have I tried Doc's suggestion of putting used filter in buckets and trying to clean and reuse them....that would certainly take a large expense down to virtually nothing. I will give it a shot before putting around 300+ dollars down for the sand filter/pump setup.
    Bob E.
    Intex 10' x 30" metal frame pool, Intex 2500 gph filter/pump, Intex Saltwater generator, SwimMax 11KW heater, 2 x Small Game Solar Domes.
    From what I've been told, you can't clean the Intex cartridges very well -- you'll need to switch to the Unicel (or probably Filbur) cartridges to operate that way.
    Also, the 2650 gallon system is a SWCG + copper ionizer hybrid system. If anyone with blonde hair gets in that pool, there will be trouble!! We don't recommend those.
    May 2012
    Oklahoma
    PoolDoc, I just ordered 3 of the Unicell B cartridges off the Amazon link. Thank you, for this experiment to work correctly, I MUST have the genuine Unicell article. I am off to buy two new 5 gallon buckets with lids that those carts will fit into easy and for the whatever of it, practice with the Intex cartridges first using the cleaning system you suggest. 50 bucks for superior cartridges and the small extra work to clean and maintain them is worth the effort to keep everything small and simple for me. Give it a couple of weeks and I will report back as to the difference between the Intex cartridges and the Unicell ones and how they both work being cleaned.
    Do you recommend I just use the normal garden hose sprayer to clean the cartidges off or is it worth the few dollars it costs for the "official" cartridge sprayers worth it?
    I need to appologize to you because just a little more effort on my part and education has got me realizing that the Intex folks while not lying about their system, my be reverting to over simplifying things. If their replacement cell is made of copper (and that's what it looked like to me when I was giving it a quick look a couple of weeks ago), then their SWCG system is using copper ionization to make the chlorine from salt. I did not realize that the expensive systems used either a plated material or strictly used exotic metals to keep the copper out of the water due to the blonde hair issues while converting the salt to chlorine. So again, I may decide it is worth my 57 bucks to order one of the replacement cells so that not only myself but everyone here knows exactly what this system is and decide to use it or keep strictly with BBB.
    Looks like Wednesday until my Taylor 2006 test kit will be at the house.
    Bob E.
    Quote Originally Posted by SafetyBob View Post
    Please do!
    I'm not even sure what the "official cartridge sprayers" are. Do you have a link?
    I need to apologize to you because just a little more effort on my part and education has got me realizing that the Intex folks while not lying about their system, my be reverting to over simplifying things. If their replacement cell is made of copper (and that's what it looked like to me when I was giving it a quick look a couple of weeks ago), then their SWCG system is using copper ionization to make the chlorine from salt.
    Wow. I didn't realize that. I'm going to have to ask PoolSean about that.
    May 2012
    Oklahoma
    Here is the link to one of them I found. I found one exactly like it at amazon from the Unicell web page from your links....
    http://www.google.com/products/catal...=0CL4BEPMCMAA#
    For right now, can't fingure out how to do a 'real" link. I assume you will have to copy and paste.
    Bob E.
    May 2012
    Oklahoma
    I got the Unicell type B cartridges today. I can report that yes they may cost 3 times as much as the Intex units AND they are built around 3 times better than the Intex cartidges too. All the filter pleats are straight and do not flex much, unlike the Intex units. It appears because of the superior construction of the Unicell replacement cartridge, the unit HAS to filter better. Example, most of the pleats on a Intex unit seem to hug each other every 3 or 4th pleat. Normally when I take the Intex unit out of the filter assembly there seems to be uneven filtering......cleaner areas versus some other areas. The Unicell cartridge filter element pleats are ALL evenly spaced and generally even all the way around the filter front to back, inside to outside. Push the corner down on any Intex filter and they bend quickly, not so with the Unicell.
    I have one Intex filter in the bucket soaking awaiting another filter change probably forced tomorrow a little early. So my feelings so far is that I bet the Intex filters can be cleaned, ya, they will be OK, but probably can't keep changing and cleaning all season long with them though. Based on construction, I am will to bet that the Unicells will take alot of cleaning and use before needing to be replaced......I am hoping the whole season. Part of my report I hope will be to also comment on if they last longer between filter changes. I notice if my pool gets used for most of Saturday and Sunday, I must change the filter out when I put the pool to bed Sunday evening.
    Hopefully more this weekend.
    Bob E.
