Results 1 to 10 of 10
Thread: Estimating size of pool
    Houston.
    Default Re: Estimating size of pool
    Are there any of the pool water tests that are accurate enough to calculate the volume of water based on the change in test results after adding a prescribed treatment? In other words, let's say I measure the salt with the Taylor K-1766 drop test method. Then I add a 40lb bag of salt, wait a day or two, and test the salt again. Using something like the pool calculator site, I should be able to figure out the volume of the water based on the change in salt PPM after adding a 40lb bag of salt.
    Are any of the other tests and treatment methods any more accurate to be able to do this? I would think it would have to be a test like Salt or CYA that doesn't evaporate or change rapidly, or an application of something maybe like bleach or acid that would have an almost immediate effect so you can measure right away without other factors affecting the results.
    Just wondering.
    Robert
    22K gallon, IG, gunite, Sunstone Pearl White Pearl plaster, Aqualogic SWCG, Hayward Tristar pool pump, Pentair Whisperflo waterfall pump, Pentair Clean & Clear 320 cartridge filter, Sta-Rite heater.
    Some years ago Que Hales of Pool Chlor and the JSPSI (Journal), published a method of doing just that, using alkalinity tests.
    You could do the same thing, using a K-1766 and salt additions. Your accuracy would be limited by the accuracy of the tests AND the salt addition. In other words, you'd better weigh the salt. You'd need to test salt levels before and after the addition. I doubt that you'd be more accurate than direct calculation, when pool layout is simple (rectangle, etc.). But, with free form pools in irregular shapes, you very well might get superior results.
  1. Liner and pool size problem
    By True Blue in forum Above-Ground Pool Construction & Repair
    Last Post: 05-29-2013, 08:11 PM
  2. Pool Size
    By tropic in forum Pool Equipment & Operations
    Last Post: 05-01-2010, 01:12 AM
  3. What size pool cover to get for 18ft AG
    By nicole12 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 07-25-2006, 02:16 PM
  4. How to calculate the size of my pool
    By Sunny32504 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-09-2006, 11:16 PM
  5. wrong filter size on pool
    By LukeNorris in forum In-Ground Pool Construction and Repair
    Last Post: 05-02-2006, 03:24 PM
