Re: Pool Opening Problems.
I know what 50 GPM looks like and I'm certain my pump does more than 50 GPM open ended. Can't really tell what the flow would be through the filter and return piping, but if you put it to waste or backwash it's at least 50-60 GPM. I wonder if there as a flowmeter built specifically for pools I can put in-line to check the flow. Also it would be handy to know when the filter is really getting plugged instead of relying on a pressure gauge.
I sized the pump /tank going by their charts-the 60D was supposed to be good up to 60 GPM and the pump was supposed to do 50-60 GPM. What I'm finding out is that I really needed the 100D (as you suggested) to handle the flow.
If I did go back to DE ( I had an old Sta-Rite Swimquip stainless DE before) which one would you recommend? My plumbing is on top, I would prefer to stay with a top mount valve so I wouldn't have to massively modify the plumbing. But I can change it if need be.
~18K gal IG Gunite -- 1-HP Pentair Whisper Flo with new 2-speed motor. Intermatic T1000 Dual Speed Timer -- Tagelus 60D sand filter
Hayward SWCG (up to 40K gal.) -- Polaris 280 and booster pump -- Rainbow (now Pentair) in-line chlorine Feeder.
