Thread: Pool party aftermath
    Default Re: Pool party aftermath
    You can take the chlorine to 15 ppm -- it definitely won't hurt anything.
    I'd also recommend leaving the cover at least partially open. After that kind of bather load on a small pool, there's a lot of gook in the water than has to be oxidized. Some of the oxidation products are noxious, but are volatile and will escape the pool on their on. However, if the pool's covered they remain trapped.
    Just as important: some types of 'goo removal' require BOTH chlorine AND UV (ie, sunlight) so covering the pool interferes. If you're not going to be using the pool for a few days, I'd turn the heater off and uncover the pool.
    If it's practical, it would also help to clean the filter, since it's better to remove the goo physically than chemically.
    However, I wouldn't be surprised if it took most of the week to return to the water quality you've seen in low use periods.
    Mar 2012
    Ohio
    Thanks so much! I did turn the heater off and will let the water temp reduce on its own. The weather in this part of Ohio is unpredictable and I can't see swimming on a regular basis quite yet. I think I will increase the FC tonight--as you say, it can't hurt. We are expected to get a few days of 60 degree sunny days so I will open the cover. My husband will clean the filter as well. Again, thank you for your help. I was so lucky to have found this forum as our pool was being installed last fall. I've resisted all "pool store schooling" and have used nothing but liquid bleach (and the SWCG)and muriatic acid. So far everthing has been running smoothly and our pool has been easy to maintain and a joy to use.
    15K fiberglass inground -- SWCG Nano pilot
    Hayward 1hp super-pump -- Sta-Rite Cartridge filter-Taylor K-2006 test kit
    You're welcome. Glad it's working out so well for you!
