Results 1 to 8 of 8
Thread: Buying an above ground pool...online
    Aug 2011
    Brownfield TX
    Default Buying an above ground pool...online
    I have been researching for several weeks here now. This will be our 3rd AGP the first two were intex, first was a 10' quick set top ring pool and the last was a 15' ultra frame pool which we had last year. The liner on the 15' pool split and I had the Walmart extended warranty on it, so they sent me a check to replace it last week.
    We are now considering a better/bigger AGP thinking of going 21' as this is as big as I can go and still be able to completely get around pool. Anyways just wondering if anyone has experience with inyopools.com they have some really reasonable prices, best I have found so far. Thinking of buying a hybrid or resin pool from them and wanted to know if anyone has one of there pools?
    Tanner
    Default Re: Buying an above ground pool...online
    Dunno about Inyo -- somebody else does, I'm sure.
    But you might look at the Intex Ultra series as well. Those have the benefit of being self-installable, which is NOT a quality of standard AG pools. Not to say *you* can't do it, but they are designed to be installed by pros.
    You can see the whole series, here: http://www.intexcorp.com/index.php/h...ame-pools.html
    And here's one at Amazon:
    Intex 54979EG 24' x 12' x 52" Rectangular Ultra Frame Pool
    If you were to buy at Amazon, watch out for the jump-off from Amazon's website; you can end up buying from a 3rd party without realizing it. That's not bad, but it does add some additional risk, though probably not any more than buying directly from Inyo. Also, with the Intex, you'll probably end up spending $300 - $600 on a bigger pump and a skimmer.
    That may not be what you want, but it gives you a place to begin comparing from.
    Largo, Florida
    Aug 2011
    Brownfield TX
    PoolDoc, our 15' pool was an Ultra Frame by Intex, we enjoyed it, but are looking to upgrade. I feel confident I can install an AGP have a mechanical/construction background and look forward to doing it.
    Thanks for the link kelemvor!
    OK, there are some example threads here. Skilled handymen can do the install, but there are 'gotchas' as I'm sure you understand.
    Jacob99 is offline Subscriber Thread Analyst Jacob99 0
    Aug 2011
    Massachusetts
    I just purchased a 30' round from royalswimmingpools.com. I found their prices to be the best. Shipping was fast and free although upon inspection I was missing 1 piece of bead receiver. I called them up and they sent it to me right away. Thought their customer service was pretty good. One of therm didn't have too much patience for my newbie questions but then that's why I come here...lol.
  1. Buying pools online?
    By tnt69 in forum In-Ground Pool Construction and Repair
    Last Post: 07-29-2011, 10:17 AM
  2. Need advice, Buying a used Above Ground Pool?
    By philamom in forum Above-Ground Pool Construction & Repair
    Last Post: 08-16-2006, 11:03 AM
  3. buying chemicals online
    By LukeNorris in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-28-2006, 10:38 AM
  4. Buying an AG liner online
    By Watermom in forum Above-Ground Pool Construction & Repair
    Last Post: 06-05-2006, 07:49 PM
  5. Buying an above ground pool!
    By jdogg in forum Above-Ground Pool Construction & Repair
    Last Post: 04-29-2006, 12:05 AM
