Results 11 to 20 of 20
Thread: Cloudy Water
Threaded View
  1. #6
    Default Re: Cloudy Water
    Regarding your pump, please take a few pictures and send them to [email protected] -- one of us can probably ID it that way.
    This is DE filter powder -- it's $30 for 25# delivered from Amazon. But it may be cheaper locally.
    Diatomaceous Earth Pool Filter D.E. 25 LBS.
    DE is used as the filter media on a DE filter, where the support for the DE powder is sailcloth membranes on plastic grids. But, in a sand filter, DE can do TWO things:
    1. You can use it to test if a filter is leaking: if you add DE, and it shoots back into the pool . . . your filter needs sand, or repairs, or both.
    2. You can use it as temporary polishing agent, to catch things the filter would otherwise miss. But, in this application, it may stop the filter up very quickly. A better choice for that purpose would be polyaluminum chloride, set up on a slow drip into the skimmer. You can do this with an old plastic cleaned plastic bottle, 2 boards, some duct tape and a bottle of PAC. Cut a hole in the bottle, and then cover it with duct take. Take a sharp pencil and pierce the duct take with a small hole. Remove the skimmer lid, put the board across the skimmer, and place the bottle so it sits on both boards, straddling a gap between them. Put a couple of cups of PAC in to the bottle, and let it drip into the skimmer as the pump runs.
    This is identical to very old school sand filter operation, with an alum (aluminum sulfate) feed, but with a better material. PAC is available from Amazon, in this product:
    Blue Wave Super Floc 4 x 1 qt.
    Unfortunately, you have to buy a whole gallon, which is several years worth. I'm sure it's available under other brands and labels, but this is the ONLY product I've been able to ID that is pure PAC. If you purchase it, do NOT operate on the "if some is good, more is better" basis -- you'll make a BIG mess. In fact, if you want to use, ask me first.
