Re: Accepting the challenge
Turning pool over to happier home owner. They were going online today to order their own test kit using the link provide on this web site. I will be a coach for them. Started showing them how easy it is to test water and talked about not putting any more stabilized shock or chlorine in the pool. The pool is making progress, still cannot see the bottom of the deepend. It has been at shock levels (25 to 35 ppm) for about a week. Vacuumed alot of sand out of the deep end today. Had home owner install a valve between pump and filter so we could slow the water down a bit. Filter is rated at 20 gpm per the side of the filter. Pump is 1 1/2 Hp pentair pump.
Will keep posted as pool clears with pictures. Just in case others want to see a really bad pool with high CYA cleared and what we had to go through.
~36,000g IG gunite -- 2Hp Pentair UltraFlow filter pump - replaced with 2 speed 1 1/2 HP ultraquite pump -- 3/4 HP vacuum booster pump -- DE filter --K-2006 test kit
