Re: salt water pool in AZ
As Steveinaz said, you will want to stay away from the minimum size units and go with something rated at least 1 1/2 to 2 times larger than what is recommended for the size of your pool.
You will not have any trouble keeping your FC readings to 5 ppm. There is a delicate balance between electric bills, Unit size, Run time and chlorine levels. If you buy the minimum size SWCG, you will have to run it more hours per day, pay higher electric bills, and shorten the life of the Cell.
As Steveinaz also said, you will love the system once you get it dialed in. I live in Mesa, and it is the best thing I ever did to my pool.
Oh and BTW the continious pH rising has nothing to do with our hard water. It is a common occurance with SWCG's. See the FAQ Stickie at the top of the Salt Water section.
Once you have a good idea of what your pool size will be and what unit you are looking at, Post back and let us know.
