Page 1 of 6 1 2 3 ... LastLast
Results 1 to 10 of 59
Thread: Chemical Help
    Apr 2012
    PA
    Default Chemical Help
    I am a pool owner for 10 years but always struggled with keeping Chlorine up...I have stabilized in the past but did not often check CYA levels.
    Last year I kept getting no chlorine or very low chlorine, low pH and high TA readings on my test strips no matter how much chlorine and pH up I added and then the water got very cloudy.
    I finally broke down and went to the pool store where they told me my TA was off the chart high and gave me "low and slow" to improve it. I was able to get the pool clear after hundreds of dollars in their chemicals.
    I went out and bought several brands of strips including a digital test strip reader and realized that the pool store was right as I had pH and TA, and I think I must have had a bad batch of strips at one point.
    Here is where I am at now:
    Taylor 2006 ordered via amazon tonight to get more accurate results.
    Chemical Values the best I can tell from 3 types of test strips (all reading the same, and are the same as the pool store):
    pH 8.1
    TA 300+
    CYA 0-30
    Chlorine 0
    I just removed the cover with semi clear green tinted water with silt on the bottom. (My pool has overhaning oak trees and I use a mesh safety cover)
    I will verify values with my new Taylor kit.
    My real question is:
    Should I stabilize before taking on the pH and TA?
    Should I wait until put bleach in until pH is ok?
    What should my plan of attack be???
    I plan on trying the BBB method but I just do not know where to start at this point since my numbers are so "off".
    (It is really crazy that I have not had a good handle on my pool for 10 years. I avoided pool stores because they always wanted me to spend hundreds no matter what my values were. I have always been good with 3" tablets and basic shock and occasional pH up until the last 2-3 years when I struggled to get a chlorine level no matter how much chlorine I put in my pool, even though the water was clear.)
    Default Re: Chemical Help
    You need to do both at the same time -- pH and chlorine. It shouldn't be a problem, though.
    1. Read through the muriatic acid guide: http://www.poolforum.com/pf2/showthread.php?13111
    2. If you are comfortable with muriatic acid, buy 1 - 2 gallons per 10,000 gallons in your pool. Otherwise, buy sodium bisulfate ("Lo-n-Slo"; many other names).
    3. Buy 6 gallons of plain 6% household bleach per 10,000 gallons of pool water. Also, buy a cheap OTO (turns yellow) drops test kit.
    4. With your pump running, and water circulating, add 1/2 gallon doses (or 4# doses of bisulfate -- dissolve in warm water, first) to your pool. Wait 4 hours, and test, before adding more. Once your pH is 7.6 or below, switch to ~1/4 gallon doses (estimate; do NOT measure muriatic!), and continue till your pH is just barely below 7.0. It will rise over time, so continue to hold pH to near 7.0, till the TA is below 100 ppm. Read this page for explanation: http://www.poolsolutions.com/gd/lowe...p-by-step.html
    5. At the same time that you are lowering pH, add 2 gallons of bleach per 10,000 gallons of pool water, each evening. (Don't pour bleach into the same area, where you just poured acid!!). Test the pool each evening; if the chlorine level is dark yellow, skip that evening's dose. Otherwise, repeat.
    6. Continue with this process till you have your K2006, and full test results. Send those results in, along with info on your pool's appearance and general information (gallons and such) and we can begin to move to next steps.
    Apr 2012
    PA
    My one set of test strips test for CYA and I am at 0-30. Should I try to stabilize first or at least get close with stabilizer before starting this process? (I expect my test kit in a few business days or a week at worst)
    Thanks for your help.
    No!
    Go ahead, and get going before your pool turns into a green swamp!!
    Apr 2012
    PA
    Ok Taylor 2006 arrived and I put one dose of .5 gal muratic acid and 3 gal 6% bleach and results as follows:
    ( I have a 18' by 36' in ground with about 22,000 gal.
    PH 7.6
    TA 240
    FC 1
    CC 14
    CYA -???? I could not get a reading. I put it the whole way to the top and no change
    Sounds like your pool may have experienced the scourge of CYA eating bacteria -- it's fairly common. The real problem is that sometimes -- we don't know when -- the bacteria 'poop' ammonia back into the pool, as the by-product.
    If you didn't make a mistake in your test results, that is almost certainly the problem (FC=1; CC=14; TC= 1+14 = 15). If this is happening your pool will likely have a strong 'chlorine' smell, from the chlor-amines that have formed.
    Unfortunately, it can take an ENORMOUS amount of chlorine to get rid of the ammonia. But, there's no other solution that doesn't cost even more. So, do this:
    1. Let the pH go back up; it will do so on it's own.
    2. Keep the pump running 24/7
    3. Adjust the eyeballs so they 'riffle' the pool surface.
    4. Add 3 more gallons of bleach, wait 2 hours, and retest. If the CC has gone even higher, we've found the problem.
    Once you've ID'd the problem, the only thing for it, is to keep chlorinating -- but let the pH stay high (7.8 - 8.0). Try to reach 25 ppm CC, and then hold it there. After a while (and a lot of bleach) the CC should begin dropping and the FC should begin rising.
    If you have a Sams Club, it may be cheaper to buy a 50# bucket of dichlor or 40# bucket of trichlor, and use them. That will not be as hard on your liner, because those will be adding CYA. Trichlor would be best, especially if you can put it in the skimmer.
    BUT, if you do this KEEP THE PH HIGH. Use borax, if you need to, to raise the pH. Borax is the ONLY chemical you can safely add on top of trichlor. Add it slowly to the skimmer.
    Apr 2012
    PA
    I have used stabilized 3" pucks before along with shock from SAMs club but I did not measure and put stabilizer in before.
    I will put the bleach in tomorrow as I am not home tonight. I will measure Chlorine before and after adding the bleach.
    OOPS!! sorry
    I must have done something wrong when testing for chlorine yesterday, sorry. Re checked my chlorine this morning... FC 2 CC 4, pH 7.2, TA 210
    (I did add another .5 gal of acid last night and 3 gal of bleach before checking forurm, thus the lower pH this morning)
    Pool still slightly cloudy with greenish tint and silt on the bottom but looking better. I may be on the right track!!!
    Thanks!!
    You can read about my personal experience with this effect in this thread including a summary of readings and amount of chlorine in this post. Basically, your CC will take a roughly equal amount of chlorine, or perhaps some less, to get rid of it, but you may also still have ammonia in your pool from the bacterial conversion of CYA so adding chlorine in that case might increase CC even further in the short-run. There's not much you can do except oxidize it all away and chlorine is the least expensive and effective oxidizer for that purpose.
    If you can, pick up a few boxes of 20 Mule Team borax, to go along with the bleach and tabs. You're still showing high CC's even after the correction, and they clean up more nicely at a higher pH level. (Plus the CCs that form at high pH are better at killing algae!)
    Apr 2012
    PA
    My FC is 2, what should CC be???
    I thought I was on the right track with FC 2 CC 4 and the pH and TA coming down.
    I guess I am confused. Is it because my cya is 0? Is it possible that I just didn't stabilize enough in the past?
    I know that I screwed up the pH and TA last year by adding too much baking soda and ph up.
  1. Need Chemical Advice
    By vvon66 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-07-2012, 10:36 PM
  2. chemical levels seem ok?
    By GerriLeAnne in forum DPD-FAS based testing
    Last Post: 07-24-2010, 03:12 PM
  3. Chemical Age
    By mohawk in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-19-2008, 09:02 PM
  4. CYA: Chemical OR Organic
    By stma in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-04-2008, 04:44 PM
  5. PH Testing Chemical
    By jrv331 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-26-2008, 08:23 PM
